Which Tuner Do You Like?
On that power vision where will you get a map for the cams or will you just take it to a shop and have them tune it? I am planning on putting some cams in my bike and was looking at the power vision but on there website I didn't find a map for my bike with a cam. I am working on getting full exh system and an intake and do all of it at one point in time.
2015 flhxs
2015 flhxs
Why is it that every time I try to understand the benefits of a fuel management system and "mapping" an EFI, all I see is this:
I'm perfectly content with my 100% stock 2014 Ultra Limited. However, if it can be made "better", then why not? I am not dismissing the possibility that I might change my bike's air cleaner, exhaust pipes and/or cams later - at which time I presume a new "mapping" would almost be required. But how about now at 100% stock? Any advice would be greatly appreciated.
UPDATE: At 2016 Americade, had an Arlen Ness "Big Sucker" air cleaner and Power Commander V added to my stock '14 Ultra. The bike was manually remapped [and if I'm not mistaken, the O2 sensors were disconnected]. Seeing is believing [a slight increase in torque and 10% increase in horsepower]. Not only is the improvement evident at the throttle, there has been a noticeable decrease in engine heat as a result of the enrichment of the AFR.
2015 flhxs
2015 flhxs
