No Device: V&H FP3 vs TTS/Kuryakyn Mastertune 2
I am narrowing down my choices of fuel management for 2016 RGU and trying decide if the FP3 or Mastertune 2 is a better choice.
At the moment, 4.5 RC slip-ons are done and a new header pipe and/or catless OEM are planned next. Header is a whole 'nother discussion, but I do also like the thought of Rush HO duals.
I don't know if I will ever do cam's etc., but wouldn't want to throw out my fuel management and have to buy again.
Looks like the price diff is about $130-140, so not a big issue. I'm computer literate and mechanical, so I don't need "simple", I need best bang for the buck.
So if I understand, both systems are similar in that 1) I can store my factory ECM load, 2) load a "base map" that is close to my configuration, 3) auto-tune the bike.
Are there any significant features of one system over the other? Do either of these allow more than one configuration at a time? Ie. A performance load and a economy load to co-exist, which can be easily flipped? (I sort of doubt it, but good to ask right?)
Seems like my local dealer is pushing FP3 (they don't sell the Mastertune 2), but I see a lot of professional tuners seem to like the MT2.
Not trying to get lots of fanboy responses based on what they bought, but would really like to know from anyone who's is familiar with (or has owned) both products and can make a factual comparison.
Thanks to all.....
Thanks to all.....
I can't speak for the FP3, but I went from the early style Fuelpak to the TTS and there is no comparison; I understand the later (FP3) is an improvement over the early models, but the TTS is one of, if not the best tuner on the market IMO. Spend the extra and get the TTS, I think you will have a much better tool (product) in the end; you (or your tuner) will have much more control over the parameters you can adjust..
I did a stage 1 with V&H 3" slash cut slip ons and as I recall that was ok but not as exciting as others seemed to suggest. I tried some autotunes but the V&H base map seemed to work better.
- FP3 didn't autotune the 0% throttle column ??
- Canned V&H maps had silly high VE values in the 0% column from 2000 revs (and I don't think chucking fuel in the engine is how you fix decal pop - of which I have none)
- You can only do anything, outside, with the FP3 plugged into the bike, and with the bike switched on ...which is a real pain if you are checking stuff, or manually trying to build tables.
- There are no canned maps remotely close for any new cams
- I didn't think their new cams feature worked, it didn't make any difference to my attempts at tuning my 57H. V&H tech support originally told me I didn't need any changes for that cam over stock ...which I now know is obviously just wrong.
- Not being able to look at or edit your tune unless it is plugged into the bike is a real pain
- Not being able to download tunes to your computer to modify or compare with previous autotune attempts is a real pain
- There is no logging (although they are supposed to be working on that)
- There is a gauges display, but only 18 signals available, but 3 of those are not worth it - Power (a guess), Torque (a guess), an Economy thingy (who knows) - they have only just added target AFR and injector duty cycles, but there is no CLI, AFF, new VE values, or Knock events
They need to add more signals and provide data logging, including knock events to allow some spark tuning.
They also need to make it useable offline - connected to your computer so that you can copy tunes on and off so that you can manually edit them or compare them to each other.
But then again, it depends what you want, and that was obviously just my 2c
Excellent explanation and will likely be significant reason for me to go with master tune over fp3. I am a profs software engineer and will take functionality over simplicity every day. I was getting the sense that all those using fp3 were happy because it was simple and had a cool iPhone app. I don't care about Bluetooth iPhone apps and will give that up for better ability to examine tables offline and tune the most parameters. I will want auto tune to work properly and that too is high on my priority list.
Thsnks
Thsnks
