The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Other Devices: SOS fuelpak
Old 08-02-2016, 09:29 AM
deekybandino's Avatar
deekybandino
deekybandino is offline
Stage II
Default SOS fuelpak
I drive a 2013 fatboy. V&H big shots, screamin eagle ventilator intake. I have a fuelpak tuner and within the last month my bike has started bogging when I start it.(really rich gas smells) and my top end speed is nonexistent anymore. goes max 110. (not that that isn't plenty, but I used to easily pin the needle at 120+) I bought the bike with everything on it and don't want to tear it all apart. was wondering if anyone had mode values for the tuner that works for them with the similar setup. its a long shot but anything helps.
Old 08-02-2016, 12:24 PM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Received 5,515 Likes on 1,613 Posts
HAs it always been this configuration, or did you add the Fuelpak and troubles started? If the issues started with the Fuelpak, remove it and see if the bike goes back to normal.
Old 08-02-2016, 12:25 PM
nevil's Avatar
nevil
nevil is offline
Is this the new FP3 or the original type piggyback Fuelpak?
If you're getting too much fuel it could be the tune or your air filter could be dirty. Easy enough to check the filter.
Sorry I don't know about the FP3 but if it's the older type sometimes the map gets corrupted and needs to be input again. Try contacting V&H and see what map they recommend.
Also check the big connector and make sure it's tight and dry.
Old 08-03-2016, 09:31 AM
deekybandino
Stage II
It's the older piggyback, air filter is good, and connection is solid. I contacted them and am waiting for a response. I appreciate the help guys.
Old 08-03-2016, 10:16 AM
nevil's Avatar
nevil
nevil is offline
Years ago I had one of those and was having some problems. They had me send it to them and checked it out at no charge. Turned out it wasn't their unit but at lease it eliminated it as a cause.
Keep up posted.
Ashnic
07-16-2015 07:39 PM
MikeLaPlaya
06-14-2015 10:01 AM
DarkStar07
2014-2023 Touring Models
17
06-19-2014 06:56 AM
katanaplanet
08-22-2013 08:54 AM
joeyh76
10-21-2008 08:24 PM
Quick Reply: Other Devices: SOS fuelpak
