DYNOJET: 110 seems underpowered
So I'm seeing that I'm pretty low. I had a conversation with Bob at fuelmoto who said that in his experience the supertrapp doesn't do as well with the 110 as I may have thought. So I may be looking at new pipes, cause I can't see leaving 10ftlbs on the table.
I saw a lot of good results with bassani rr3, but I'm not familiar with the B1. I'll have to have a look, cause it seems that the supertrapp may be the issue.
Thanks for the info guys.
I wish I was closer to VA or TX as you two are some of the good ones...
Thank you for the kind words and I would be using the pipe you have it works great its a tune issue not a pipe issue. The supertrapp is a great pipe for power you just need to find a tuner that will test different configurations with the discs and your power will be exactly where it needs to be. The pipe I have on mine and those other two dynos is the Bassani Road Rage 2 B1 power 2/1 systems in black of course.
Depends on where in NY you live, but here's a link to some dyno shops https://www.zeemaps.com/map?group=1976040# Maybe take a look and see if any are within reasonable distance to you, if so start a topic asking for feedback on them.
I have seen the supermeg touring 2-1 support over 140/140 plus. IME Cam isn't the deciding factor on disc count. Engine displacement isn't the deciding factor. It is both and everything else and the only way to know is to test and verify. Closed end cap has done better for me 90% of the time.
I hear suggested disc count and Trapp told me anything over 23 and a CEC is a wastes of time. I disagree. I have a 95 hippo 570 build on a 2003 touring that has 26 and CEC in the 100/100's. I have a 124 w/ 640 that hit 140/140 plus with 20 disc CEC. My personnel 124 has 33 and a CEC. So, test and verify.
Then I took it to another tuner - Westchester Powersports for a full tune and basically got the same tune as was on the bike when i dropped it off, with some VE changes. No hp/tq improvement. In fact it was .5 tq lower!
I was going to go up to the HD dealer where Vdop works for their dyno, but I got lazy and went to WP who is only 30 min away instead of 2.5hrs away. Thats what I get for being lazy.
So i'm $900 into dyno tuners and still at 106.
Not having luck with tuners in the area.
