TTS: Locking to ECM
#41
Jason
I need you to tell me Exactly what Emergency unlock file you tried, since there isn't any for the 2017 Street currently.
When you said the SESPT got to 98% what was it doing?
Your bike is a non USA model and I think that may have something to do with it but I am not sure. Your help in telling Exactly what you did will help get to the bottom of it much quicker.
please read my replied posted, I did answer all your questions.
#42
I believe, if you give Steve the info the way and time he asks, he may just be able to get your bike out of its EFI delimma.
I say this because I too have not understood which file you attempted to put in you ECM since there are no cals listed for your bike in the TTS recovery site.
I do not understand what "98%" meant when you referred to the SESPT since you also stated it never started.
Also there is no "login" to the software in the ECM.
And lastly, AFAIK, you have not "quoted" the error messages?
I realize frustration abounds here but Steve is capable and will figure this out and fix it.
That said, if you are into trying all the tuners on the market you will need to precisely follow programming conventions to keep all the different system separate.
Again ,answering Steve (again?) even if you feel you have already provided the info, will assure faster resolve than frustrating Steve.
Bob
Bob
#43
Best I can tell is the 98% it got to was trying to load a TTS Cal back in the bike. From what I can tell he was not able to get the FP3 or the SEPST to connect to the bike. I have a hunch that the TTS was unplugged or the bike powered off during the flashing process and now the ECM is corrupt. It wouldn't be the first time it's happened.
#45
I believe this can be straightened out with accurate, complete info.
I wouldn't let a dealer get near my ECM unless they are just looking or diagnosing BCM and/or fob issues.
It's too easy for them to decide a bike needs an "update" calibration...wiping out the "good" tune and replacing it with a stock, untuned, cal.
Thanks again to TTS for protecting the ECM so no one can arbitrarily decide a different cal needs to be installed wiping out the tuned cal.
Bob
Bob
#46
[QUOTE=Wide Open Cycles;16053437 I have a hunch that the TTS was unplugged or the bike powered off during the flashing process and now the ECM is corrupt. It wouldn't be the first time it's happened.[/QUOTE]
Only time I have seen it happen. Sent the ECM and VCI to Steve. Told him what I did and how I screwed up. Fixed me right up.
#47
It's happened to me a few times, I tripped over the cable once and it unplugged in the middle of the flash. Another time the SERT program crashed during the flash. That computer didn't have enough memory. It's not anything that can't be fixed, just a PITA when it happens. You learn real quick to not do anything else while the CAL is loading to the bike. I have a suspicion that that is what happened in this case.
#48
TTS tuner is a good product and excellent service no doubt about it. Unfortunately, TTS basemap not ready for my 2017 street model I am sure they will release it soon. Thanks to Steve he had following my case status for month. I did sent my ECM and TTS interface to Steve to help me fix it, I hope my bike in the wind soon.
#49
