No Device: Brief Synopsis of Tuners
I am helping a buddy upgrade with 2012 Road Glide. I put together a list of the tuners I found online and was hoping someone could give a brief synopsis of each to help me figure out which would be best for his application..
So far I have found:
Power Vison Basic
Power Vision Basic plus At-100
Power Vision Basic Target Tune
Power Commander V
Fuel Moto Micro
FuelPak FP3 V&H
Thundermax with Auto Tune
TTS Master Tune
Thanks guys!
Power Vison Basic
Power Commander V
Fuel Moto Micro
FuelPak FP3 V&H
TTS Master Tune
Thanks guys!
I've been researching this for about 2 months and have decided I will purchase the TTS also.
However, I think the selection of tuner should be based on:
1) What changes will be made to the bike (don't forget to consider possible future modifications as well)
2) Who will be doing the tuning
a) If professional on Dyno, then consult with the tuning professional to see what he is recommending
b) If doing yourself, I think it depends on how technically inclined you are and how much time (learning) you are willing to invest into getting the most out of the product.
So:
- if you are doing slip-ons and maybe an A/C, then perhaps the FP3 or FM Micro is all you will need
- if doing header pipes (or more), then I would consider TTS or PV
I can't comment on Thundermax, but in my opinion - I want a product that can be tuned by a professional (or myself) and do NOT want to swap out the ECM
My understanding on the PC V is that it is being replaced by the PV (others will undoubtedly correct me if I'm wrong)
My decision to go the TTS route is based on me being a very technically inclined person, well versed in computers, programming, table driven lookups, etc. I believe the TTS is superior in it's sampling rate, output of "raw" ECM data for analysis and modified code routines that are loaded into the ECM. Also, it will not leave a "fingerprint" (the PV will according to what I have read) should I want to re-flash my ECM back to it's Harley Factory image. I believe the TTS allows you to really control areas of the ECM that others do not. HOWEVER, Just because it provides these features does not mean the average guy (including me) should mess with them. In the hands of a professional however, they will get every last lb of torque or HP out of the v-twin. I do intend to get the bike dyno'd down the road, so for me the TTS is my choice.
For the less technical types, the PV may be easier to use and does have some nice features that the TTS does not offer. The screen allows easier loading of ECM images, including the ability to store several in the device itself for sudo-on-the-fly loads. I believe the display will also show some nice information like fuel consumption engine temperatures, and other operational statistics, etc on it's display. Nice to have, but once the engine has been tuned, I wouldn't see needing this information on a daily basis, so I'd remove the screen anyway.
Both the TTS and PV have the ability to record while you ride for performance tuning purposes. While the tools are different, they provide a way to use this recorded information to create a calibration file based on information collected during the ride. TTS will require a PC to use the Vtune program where I believe PV can do some of this in the supplied display. It's my understanding the for a more accurate calibration, the PV also uses PC software, so you'd still use a PC.
There are many thread on this site and others and you can read for days. I have. The above information is my opinion based on reading all the "facts", pro's and cons of the various tuners on the market. Be careful when reading some of those threads as much of the information is OLD, biased based on ownership, or incorrect assumptions passed on from those who pertain to "know".....
I have talked with Steve (TTS manufacturer) and Jamie@FN (PV distributor) several times. They are both very helpful and have good products.
Like I mentioned earlier, I've been researching this for several months. There is a lot to take into consideration. I've flipped back and forth a few times on TTS or PV, and although I haven't made the purchase yet, I'm 99% certain it'll be TTS
Hope this helps.
So:
Hope this helps.
Wide Open Cycles (10-19-2016)
I wish everyone did the research you've done before purchasing.
i believe everyone would come to the same conclusion.
So:
Hope this helps.
So:
Hope this helps.
Steel Steed
19
04-27-2016 06:59 AM
