DYNOJET: Power Vision Target Tune
#111
The reasons to have a well tuned engine are for longevity and optimal performance. If you ask me if or possible to use the devices on the street to get a decent tune I would say yes,with enough time it is possible. The main problem I see with auto tune (both basic and pro) is that whole you are out data collecting you are riding a bike that is not in tune.
#112
I agree with the above that is why I think you should only do short runs and apply the changes, rinse and repeat to quickly get the VE's heading in the right direction, stage 1 and even stage 2 with mild cams is not so much of a worry but if the engine is significantly altered from what cal you are using to tune from then street tuning has a greater chance of causing some damage, that is my diy approach anyhow. Good thread by the way, good to see some tuners hanging in there
#113
#114
#115
I too believe with some understanding of what you're trying to achieve and accurate analysis, the "DIY" outcome can be tangibly better than a poor session with an old dyno and less skilled/ informed operator. This has been my paid for in $ experience.
Some of us live in areas where there is no access to the latest equipment or knowledgable operators. I live on what most here would consider a small island.
A decent outcome, taking small bites as Hilly13 has suggested can, in time, yield a result which is decent/good.
My bike is currently "stage3-4" for want of a better description and not the first EFI bike to be "tuned".
I'm appreciative of the temper shown by those skilled in both word and deed to try and explain, without hysterics, the benefits and possible pitfalls of both options and the tuning systems used to achieve those outcomes. Thanks for sharing.
I need a drink!
I need a drink!
#116
#117
While what you say is true mirrmu surely you would agree that a well tuned bike is not only a pleasure to ride but that calibrated configuration is better for the bike mechanically for lots of reasons?
Of course how an engine is treated has a part to play in longevity as well but lifters do fail, I've seen them, cranks do chew up oil pumps, I've seen that too, my 2016 FLSS will eat the oil pump eventually if I don't do something about it, .0075" runout from new does not lend itself to longevity, a 2006 FXDWGI that I used to own had only .0015" from new, luck of the draw it seems.
#118
#119
It would be an unnecessary expense as your autotune system "should" have handled any fueling issues.
Timing can be changed with either system.
Target tune requires removing and installing sensor bungs so you can replace your OEM sensors with the aftermarket ones from Dynojet.
Just simply not necessary as the end result will not show significant improvements over your existing system.
Bob
Bob
#120
