DYNOJET: Power Vision Target Tune
If you live by a competent tuner then I would have it tuned by them. However there is a lot of tuners that say they know what they are doing but the results will be less than desirable. That has been my experience. I have the target tune and my bike runs great.
I have the PV/TT combo installed on my 117" build and I will say it makes parts swapping a breeze. I recently swapped exhausts from a 2/1/2 to a 2/1 and the tune was very simple unlike having to get a flash or having it dyno tuned again. It does a great job honestly. When I installed the TT and a TT map I completed the recommended 3 - 20 minute AutoTune runs. Motor seemed to dial right in. I later took the bike to a local "knowledgable Indy" and had the bike dyno'd. They were only able to get me 1HP and 1 TQ.
I am a fan of the combo and presonally find it well worth the investment if you prefer to do your own parts swapping or tuning.
Just my two cents.
Just my two cents.
For a known setup, the right spark and AFR table to produce the best performance should pretty much be known and should have little - if any - variation between one unit to the next. If this were not the case then every stock motorcycle off the production line would have to have a custom tune for it.
So a guy wanting to do a stage 1 on his otherwise stock engine should be able to get a good AFR and spark table for that engine (but not the factory tune, mind you). The focus of his effort is to compensate for the changes caused by the custom pipes and air intakes that he chooses to install. That means dialing in the VE tables. PV Autotune (especially w/Target Tune) fills this bill (among others).
I use the AFR and spark tables in the specialized Target Tune tune file for my setup (stock 1200 EVO on '09 Nightster). I asked if they develped/dialed in that tune (specifically the AFR and spark tables) on the Dyno. He replied that they did. So - as the theory goes - that tune should be good to go (AFR/spark tables) for any other stock 1200 EVO.
...and a stage 2 with a popular camshaft like the 57H should be able to use someone else's stage2 with 57H map...
...good luck with that one.
Slip a bit more compression or anything past a stage 1 for that matter... well, yea, on you go. The built in auto tune on narrow bands gets you just as close tbh
PV + TT is one helluva price for a stage 1 btw ??!? each to their own I suppose
Yes... But...
But what do you have at the end of the day when you've had a custom tune done via a dyno? Just the tune. A tune that you hope was done well. A tune that will likely have you running fully open loop and requiring O2 sensor eliminators.
At the end of tuning with a PV+TT, you got the tune, the tune isn't a mystery, you've got a PV, and you have a TT with widebands running full time closed loop.
Something to be said for each approach. Just depends on why you want in the end.
