The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Power Vision Target Tune
Old 11-25-2016, 06:30 PM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
Question Power Vision Target Tune
Wanted to hear from riders that have installed Target Tune to their PowerVision tuner- how is it working for ya'll?
Old 11-25-2016, 07:12 PM
Tired's Avatar
Tired
Tired is offline
Received 4,451 Likes on 1,693 Posts
Mine runs pretty good on it. But it ran pretty good on the narrow bands also. Did seem a little smoother on the wide bands though.
Old 11-26-2016, 10:15 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,030 Likes on 651 Posts
I don't really notice a difference at cruise but where it is extremely noticable of the improvement from target tune, is the low rpms. I am very happy with it
oldhippie (09-14-2017)
Old 11-27-2016, 09:23 AM
Reindeer's Avatar
Reindeer
Reindeer is offline
What's the difference between target tune and auto tune?
Old 11-27-2016, 10:58 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Marketing
Old 11-27-2016, 11:58 AM
T^2's Avatar
T^2
T^2 is online now
Received 1,152 Likes on 720 Posts
Actually there is more than marketing that's different.
There's Autotune Basic, Autotune Pro, and Target Tune.
Autotune Basic uses the Powervision and your narrowband sensors for tuning.
Autotune Pro uses wideband sensors, a special control module, and your Powervision for tuning. Like Autotune Basic, Autotune Pro setup makes adjustment to you tune when it's downloaded. Most noteably to the AFR tables are adjusted (everything set to 14.3 for Autotune Pro). When tunning has been completed, the module and wideband sensors are removed, narrowbands are reinstalled, and your AFR's are restored etc.
Target Tune should be thought of independently to Powervision. Yes Target Tune can and does work with Powervision, but it's designed to be a permanent install that allows the bike to run full time closed loop. You can (and should) Autotune with Target Tune/Powervision. Unlike Autotune Pro, changes are not made to the AFR tables. So if you have a desirable AFR table loaded in your tune, Target Tune will Autotune with it. Once Autotuning is complete, the Target Tune and widebands remain in place and you run full time closed loop thereafter. The Powervision can be removed or left on the bike per the user's preference. Again Target Tune and Powervision should be looked at separately. They are not dependent.
The following 2 users liked this post by T^2:
16_Tri-Glide (05-29-2020), ReDo (10-27-2019)
Old 11-27-2016, 02:38 PM
msocko3's Avatar
msocko3
msocko3 is offline
No such thing as auto tune, they all require some form of operator intervention to get the most out of the engine.
Old 11-27-2016, 03:52 PM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
Default Cleared that up for me.
Autotune Pro uses wideband sensor, a special control module, and your Powervision for tuning. Like Autotune Basic, Autotune Pro setup makes adjustment to you tune when it's downloaded. Most noteably to the AFR tables are adjusted (everything set to 14.3 for Autotune Pro). When tunning has been completed, the module and wideband sensors are removed, narrowbands are reinstalled, and your AFR's are restored etc.
Target Tune should be thought of independently to Powervision. Yes Target Tune can and does work with Powervision, but it's designed to be a permanent install that allows the bike to run full time closed loop. You can (and should) Autotune with Target Tune/Powervision. Unlike Autotune Pro, changes are not made to the AFR tables. So if you have a desirable AFR table loaded in your tune, Target Tune will Autotune with it. Once Autotuning is complete, the Target Tune and widebands remain in place and you run full time closed loop thereafter. The Powervision can be removed of left on the bike per the user's preference. Again Target Tune and Powervision should be looked at separately. They are not dependent.
Okay, good to know. So, I have V&H Propipe on my 2011 FLHRKC, I think I have 12mm O2 sensors ( narrow band ) - can I get 18mm O2 bungs to weld in the head pipe so I could run a Target Tune?
Old 11-27-2016, 05:59 PM
T^2's Avatar
T^2
T^2 is online now
Dynojet ships Target Tune with two straight 18mm bungs. You can also get 45 degree bungs should they be needed. They are widely available. If you have an appropriate spot on your pipes to weld the bungs you should be good to go. I would consult Dynojet for the maximum distance form the heads that the O2 sensors can be placed etc. Details matter when installing bungs.
Old 11-28-2016, 04:46 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
comes alive when Target Tune is mentioned, hehehehe
Quick Reply: DYNOJET: Power Vision Target Tune
