DYNOJET: Can the Power Vison extract 2 tunes from the same bike.
Based on some videos and reading, I believe that is correct. What I an curious about is can I save the "Original tune" as well as a tune from a street tuner...
I suppose I could always load the tune again from the street tuner...
So could I buy a PV, have it save the original tune and then later if for instance a tune was loaded from the street tuner could I then tell the PV to extract and save that as "Original Tune 2" or something and not have to get the SE Street Tuner back out if I ever wanted to go back to the SE Tune.
Now I know this all sounds a little crazy, but I would like to be able to return the bike to an emission compliant tune with either stock or SE parts... If I could get the SE tune into the PV then I could use it as a starting point for an AutoTune too I guess...
So could I buy a PV, have it save the original tune and then later if for instance a tune was loaded from the street tuner could I then tell the PV to extract and save that as "Original Tune 2" or something and not have to get the SE Street Tuner back out if I ever wanted to go back to the SE Tune....
Super38 (11-27-2016)
I read, re-read, and watched a couple vids before I started using my PV. I've made mistakes with it, all were easily and quickly corrected, but overall have found the PV to be the easiest, most versatile and effective tuner I've ever used. Based on the questions your asking, I'm sure you'll also have a good experience.
Thingfish
Milwaukee Eight (M8)
10-26-2017 10:24 AM
