The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
I somehow missed the FNL176-04 file. It seems to be a winner! I think I can v-tune with it. Thanks!
Sorry someone didn't get back to you as quick as it should of happened but we have been very busy. This is the first I've seen of this but for a custom base calibration, we would need a little better information to get one going for you. What type exhaust, what size injectors and what size throttle body to go along with your heads, cam and pistons.
Hi Steve
I understand Vickie is very busy, but I'm not getting a reply either
I have a vci and a replacement ecm in there that have to be married.
Can you check to see where it is in the queue and give it a bump ?
Thanks
Hi Steve
Thanks
It is being worked on tomorrow afternoon they tell me, will know more by the end of the day tomorrow.
If I did this right the calibration is attached here. I had to zip it so it could be attached here. For the record I am pretty sure your going to get into trouble with the stock injectors being to small for your build.
Thank you, Steve. I can't tell you how much I appreciate this. I plan on a tb and injector upgrade before the dyno tune. What injectors would you recommend?
