Other Devices: FP3: What map?.. no response from V&H
Data-logging is in the works as with many other cool new features.
Remember you can screen shot from your phone and compare from the screenshots until you guys can make it happen. And thanks for following this! I can supply all the coffee you need to keep you going!! LOL
Well I certainly do like this! This is fun! I should be able to finish up tomorrow with the autotune. This is only 30 minutes worth of autotune after about a 1 hour test ride with the V&H map. Which BTW seemed to be spot on with no issues! I know I sound like a nerd but I get paid to be a 53 year old Nerd/Geek so it comes natural!! LOL
Chris, looking at iglide's screenshot ...why are we still not learning the throttle closed column?
iglide, quick suggestion maybe you could try getting a few more launches in there, maybe using second gear, to help get a few more cells at higher throttle position between 750 and 1500 rpm ...just a thought
Absolutely! I am going to do some more tomorrow morning. I was not able to see what was going on today in real time as i could not see my iPhone without my glasses. It was all a blur LOL. And my sunglasses are polarized so you get the picture. I will focus on quick 1st and second gear pulls.
So i have a question that I am not clear on. I flashed the tune to the ECM by selecting the lightning bolt in the upper right corner. Went through the power off/on and was saved. I then went back into autotune and it pulled up the blank cells. I selected stop autotune at the bottom left to turn off the feature. It then flashed again but there was no cells populated. went through the off/on and again saved. did this clear out my map? or is my autotune map still there? Not very clear on this process.
