DYNOJET: Low MPG 2016 Heritage
I have a 2016 heritage ride two up most of the time hardly never get above 3000 rpm. Have V&H big shots, Screamin eagle air filter, Power vision target tune. I have all VE's set and my average mpg is still 34 miles per gallon. This has been the average even before the autotune had begun. The bike runs great. No running issues. I am tuning off the map sensor and not the throttle blade position. What am I missing or what can be done?
Here's what you're missing; You don't need a tuner for the engine configuration you have. Yeah, that piece of crap power vision piggy back garbage tells lies to your stock ECU. Take that power vision and throw it right in the garbage! Get your stage 1 download from the stealership and let your O2 sensors on your headers do the talking. That's all you need!
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Mr. Wizard (02-22-2017)
msocko3 (02-22-2017)
Thanks Jamie
I believe you may have products mixed up. Dynojet Power Vision/Target Tune is not a piggyback device; Power Vision is a full featured ECM flash tuner and Target Tune is kit that converts the OEM narrowband closed loop system to incorporate Bosch wideband O2's directly into the H-D Delphi ECM. This can be used to tune anywhere from stock up to highly modified engines.
dohadex
11
04-13-2011 08:53 AM
