DYNOJET: New tune - New device?
Hi guys,
Thought I'd post up some questions here re: a planned new tune and whether it's worth it to get a new tuning device. A few specifics of my current build/tune:
103"
Ported heads with larger intake (1.6" or 1.8" intake? CRS) stock exh valves
Andrews 54H cams with SE 1.725 rocker arms
HPI 54mm TB
V&H V02 intake
V&H 2-1 pro pipe/baffle mod
H-D SEPRT last tuned in 2012 by A Harp at Kutter
Fast forward five years and I'm contemplating a new tune. Not too unhappy with the bike performance but thinking it could be a bit better. My tuners of choice this go round would be my SEPRT or switch to a PCV or PV. Which leads to my main question: Do/are the current crop of PCV or PV tuners capable to enough additional tuning to justify the cost expenditure? A SEPRT tune is in the area of $300. The PCV/PV tune cost is approx same + licensing fee + device cost (PCV). I could use a buddies PV and just pay licensing + tune. NOT a question of tuners but whether the benefits/capabilities of new/current devices are worth the extra cost? Thanks for your experienced input.
103"
HPI 54mm TB
V&H V02 intake
There is absolutely no reason to buy a new tuning device.
What you have is more than capable of handling any tuning issue your build could throw at it.
That said, it's important you find a competent tuner who uses the SEPST routinely.
If you are bent on buying a new device, it is more important to buy the device whatever the chosen tuner prefers. The results will be directly related to the tuner's ability to use the tuning system to its full potential.
HTH,
Bob
HTH,
Bob
Hi guys,
103"
HPI 54mm TB
V&H V02 intake
103"
HPI 54mm TB
V&H V02 intake
Ok so you are not planning on changing anything just simply freshening the current tune.. Do you think there are issues? One thing for sure changing tuners won't get you much.. If you plan on retuning, check fuel pressure / system first..
OLD 96
01-07-2018 10:50 PM
Gunnysgt
13
03-28-2012 12:00 PM
