The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: SE pro street tuner
Old 02-20-2017, 01:08 AM
jasonvo's Avatar
jasonvo
jasonvo is offline
Default SE pro street tuner
Hi everyone,
I have issued with SE pro street tuner please help. My computer recognize VCI and ECM, I program Data recording no problem but when in program mode it won't worked. I had uninstalled and reinstall a fews time not worked, I charged battery full didn't help, software install in C drive update ok but failed if I install in different drive. Thanks for any tech support.
Attached Thumbnails SE pro street tuner-img_1851.jpg   SE pro street tuner-img_1852.jpg   SE pro street tuner-img_1854.jpg   SE pro street tuner-img_1855.jpg
Old 02-20-2017, 08:57 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,252 Likes on 3,626 Posts
This looks to be a problem with download of the program from HD.. Try downloading the program from HDs web site then installing by using "run as admin". Simply running Street tuner as admin may work also. Since the program installer sets up a link to access HD every time the program runs, your anti-virus software is likely blocking access.. I use Kaspersky anti virus and get a number of pop-ups from Kaspersky asking if the HD software should be allowrd to make changes. Your anti virus software may simply be blocking that access causing the install to fail..
Old 02-20-2017, 12:32 PM
Br125's Avatar
Br125
Br125 is offline
I would uninstall and then re-install it from the website and it shouldn't need to check for updates.
If you find the folder that it installed to, you may find a lastupdate.txt file that you can change to today's date and then try again.
The file should be located on the PC somewhere like this:
C:\Program Files\Sreet Tuner\Applications\lastupdate.txt
Old 02-20-2017, 09:38 PM
jasonvo's Avatar
jasonvo
jasonvo is offline
I will try. Thanks
Old 02-21-2017, 09:48 AM
jasonvo's Avatar
jasonvo
jasonvo is offline
I tried all that, install and reinstall without any problem. The computer did setup DVI for offline recording data but VCI won't program. Weird
Old 02-22-2017, 06:40 PM
Max Headflow
I thought it had to program the VCI for no PC recording.. At least that is what I see.
Old 02-25-2017, 05:41 AM
jasonvo's Avatar
jasonvo
jasonvo is offline
It will program VCI for data recording on the flight but won't flash ECM with new Tune. I contact HD they want me to bring it to local HD dealer to use their tool, something wrong here.
Old 05-08-2017, 03:33 PM
mdaniels's Avatar
mdaniels
mdaniels is offline
Stage I
Hello, I'm running into the same issue... just wondering if you got the update to work? Thanks.
Old 07-12-2018, 02:03 PM
David Vitta's Avatar
David Vitta
David Vitta is offline
Stage I
It is actually the firewall setting which blocks these access. A few changes to the settings and updating the software will do it. Get it done from K7 Antivirus Customer Support if you need to. If you disable the advanced settings then it won't block the access most probably.
Erilflynn
01-21-2022 10:12 PM
Ryder206
06-29-2019 07:15 PM
timhdfl
08-11-2018 05:42 PM
msocko3
28
05-06-2012 06:22 AM
jmoore9
04-20-2011 09:56 PM
Quick Reply: HARLEY: SE pro street tuner
