HARLEY: SEPST help
The violet region is currently selected;
The turquoise region indicates that these values were changed;
The red indicates that these values are at their maximum allowable values;
The green indicates that these values are at their minimum allowable values;
Cells in the Air-Fuel table (whether displayed as ratio or lambda value) that are displayed in bold font are in closed-loop control.
White cells are unchanged.
From the help file-
If you start with a calibration that is too rich (per your log data) for your build, Smartune cannot get close enough signalling to work as expected.
You would need to identify where the excessively rich condition(s) occurs and enlean that area so Smartune can do its job.
Or maybe a better/closer calibration is available and would work better.
Without the build/exhaust particulars all anyone can do is a WAG.
Bob
Bob
Bob
Bob
yea I think I might try that . I talked to my local guy who does dyno tuning and he told me that when you add cams it usually leans out the bike and I'm running rich so idk I guess I will try another tune
Duke of HD
06-09-2009 08:40 PM
