The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: 2006 street Bob running on 1 cylinder
Old 03-27-2017, 06:52 AM
stewart1962's Avatar
stewart1962
stewart1962 is offline
Default 2006 street Bob running on 1 cylinder
My 2006 street Bob decided to only run on one cylinder toady after a run out.
It's the rear cylinder, checked for a spark and the plug is sparking fine. Doesn't seem to be getting fuel.Used to have a hyper charger on it and fuel pack, but now it's back to standard. It has done about 200 miles since put it back to standard as the fuel pack was playing up.
Any ideas on what to check would be appreciated.
Old 03-27-2017, 02:16 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,225 Likes on 3,608 Posts
Broken injector wire..
Old 03-28-2017, 01:17 PM
stewart1962
Thanks, worth a check. ��
Old 03-29-2017, 12:51 AM
stewart1962
A guy put a new O ring on a vuccum pipe today and new plugs. Ran ok for 5 miles then back on to 1 cylinder, left it an for hour and lunch, then drove home, about 3 miles and it was running on 2 cylinders again. My friend has a similar problem with a fatbob, and it was the ecu, seemingly it's a know problem that Harley won't ambit to, I haven't heard about it though. I'm going to clean the crank case sensor today to see if that makes any difference. Could it be the coil pack breaking down when heats up ???
Old 03-29-2017, 01:00 AM
Max Headflow
What's the problem HD won't admit to?
Old 03-30-2017, 12:32 AM
stewart1962
According to a mate of mine, the ecu's packing in. I've never heard of it though.
lmarkie
10-13-2018 11:41 PM
Anthony Monzon
Engine Mechanical Topics
11-18-2017 02:01 PM
stewart1962
General Topics/Tech Tips
03-27-2017 12:56 AM
blrobbins3
09-09-2015 10:33 AM
longrider1956
Exhaust System Topics
05-30-2010 04:09 AM
Quick Reply: HARLEY: 2006 street Bob running on 1 cylinder
