Best in fairing am/fm/wb antenna
Old 09-18-2014, 03:56 PM
trace2008's Avatar
trace2008
trace2008 is offline
Received 6,557 Likes on 3,121 Posts
Default Best in fairing am/fm/wb antenna
i have an 08 ultra and i would like to make the TP removable.
i have searched a lot of old threads and see that most antennas made for in the fairing do not work as well as the whip.
i have read that you can coil up the coax and using the original whip bent to fit in the fairing, but none of them state what sort of loss can be expected.
would the whip still out perform aftermarket when installed in the fairing?
is there any one aftermarket antenna that is better then the rest?
Thanks in advance.
Old 09-18-2014, 04:03 PM
fireman9170's Avatar
fireman9170
fireman9170 is offline
i have the HD one, seems to work ok so far
Old 09-18-2014, 04:45 PM
Mr HOG's Avatar
Mr HOG
Mr HOG is offline
I've tried two different aftermarket hidden antennas and neither performed very well. I doubt there is anything out there that will get close to the performance of your standard whip antenna. As long as you are 15-20 miles from the station, the hidden antennas work fine. But if you ride in the "fringe" zones a lot then you will be disappointed. Personally, I don't listen to the radio much anymore. If I want some tunes I just use my IPOD.
Old 09-18-2014, 04:51 PM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
I have the HD inner going into my RG as I type this. Don't really care about how well it works so much as I rarely listen to the radio. Just wanted to get rid of the whip so I can put clean fillers between bags and fender as I hate that gap..
Old 09-18-2014, 05:07 PM
Freebirdsride1's Avatar
Freebirdsride1
Freebirdsride1 is offline
I using the J&M fairing ant. it work OK in the valley us the aux. i-pod for the mountains
Old 09-18-2014, 05:27 PM
fireman9170
i use the iPod as much as possible
Old 09-18-2014, 06:05 PM
batman.'s Avatar
batman.
batman. is offline
Thanks in advance.
Some have ran there whip antenna up the frame under the tank and seat and say it works great. I got the hd hidden one and it sucks to say the least. So I upgraded to xm and that hidden one is good here in michigan but when in pa and nc in the mountains it still cut out.
Batman.
Old 09-19-2014, 07:40 AM
trace2008's Avatar
trace2008
you are using the whip inside the fairing, or on the back?
Old 09-19-2014, 07:42 AM
trace2008's Avatar
trace2008
i mostly listen to an mp3 player as well, but i do listen to the radio some and i defiantly listen to the WB at times
Old 09-19-2014, 07:43 AM
Hecklerboy's Avatar
Hecklerboy
Hecklerboy is offline
I bought this guy off Ebay for $19 and love it.
I get better reception with it than I did with the stock antenna.
Simple plug and play.
http://www.ebay.com/itm/Hidden-Anten...ht_2668wt_1362
Quick Reply: Best in fairing am/fm/wb antenna
