XM Radios
under fairing.
another option:
copy there hard drives,about a terabyte. ask a kid to hack it for you...not good for talk shows.
I may try putting the bigger antenna outside fairing again ,some areas it doesn't work as good not sure why, NY through-way good, pa turnpike cuts out??
another option:
Overpriced considering the limitations with signal, sound quality, and volume.
I don't have one on my bike, but the one in my semi has a built-in fm transmitter. All I do is tune it to an unused fm station or one that's low powered & select the same frequency on the Xm unit & it'll play just fine.
I have my antenna mounted on a metal plate attached to the top shelf of the inner fairing. I run my XM through my Zumo 550 GPS. Had to add a small 45 watt amp on top of my radio to get good volume. Now everything is great. Well, except for the yearly subscription. Have to constantly threaten to cancel, to get good deals. OH well, life is good.
That's the only way I've seen too. My Onyx does the same thing, just sounds better with the aux in or fm modulator.
Unfortunately the XM module in the 14 Ultras are complete crap and will drop signal constantly in any areas with trees, hills, power lines, etc.... The problem isn't exactly the antenna but the buffer built into the infotainment system. It doesn't have one or more correctly it has a 2-3 second buffer only. For it to be an effective buffer you need at least 15-30 seconds, which is what you get in your vehicle which is why you have less drops. I'll bet that no matter where you put your antenna you'll be frustrated with your coverage.
To counter I cancelled my XM subscription on the bike and just use their online feature. Connect your phone through bluetooth the the infotainment center and stream your XM music from the internet connection. Much more stable.
