cam upgrade question
Neither of the cams will fit the 2000 as the inside cam bearings are smaller. I would go with something like a 26G. Stay around 500 lift if engine is stock. There are several others that really need more compression like the S&S 510G or the Andrews 37G. You will need a tuner also.
If you don't want to tune with a tuner you'd want to go with Andrews 12g cams as they are similar to the stock grind and no retune necessary.
I have a 2000 King classic as well with 23k. I really don't need any more performance from the motor as it runs strong with just the stage 1. I plan on just the SE cam plate and high volume pump upgrade. I did however think about putting the FULLSAC dual setup on while the pipes where off but I'm concerned that it may cause problems with the M.M. fuel injection. I have heard its a poor system to try to tune even though they say a tuner is not required.
S&S 509 EZ start cam....
http://www.*****************/forums/...un-review.html
https://www.hdforums.com/forum/touri...installed.html
type in v-twinforumdotcom in the above link or just google it...
