Bike Barely turns over
Hey, I need some help diagnosing a problem. 2010 RK, 103 with compression releases, 255 cams. The bike barely turns over and starts. When it is hot, it seems to compression lock and barely turns over and starts. I don't know if it is a starter, the battery, compensator or what the problem might be. I do use the old trick and not allow the fuel to build to pressure and that helps some, when I remember. How do I diagnose? The compensator was replaced with one of the newer revisions than stock, the battery is 2 years old and connections are tight.
Could it be the starter? The stress of not having compression releases and such for the first couple of years could have taken a toll on it.
I really don't want to take it to the dealer because they know less about these bikes than you do.
Thanks.
Thanks.
I'll bet its the battery or battery related. You are describing the exact same symptoms my 2010 had when its battery was heading south. I put a multimeter on my 3 year old battery and and it would test like new. Leave the multimeter on it and hit the start button and it would drop under 10V. That was enough to cause the exact symptoms you describe.
Also, make sure your battery connections are not just tight, but properly torqued. The proper torque is required to get a good connection.
Good luck.
Good luck.
Thanks.
Thanks.
Test the battery to rule that out and check the CR to make sure they are working. Tight connections.
If the above checks out then yes it is the starter.
Two months ago I replaced the battery as even though it tested out volts and load. Made no difference. Meanwhile since I already had one starter clutch go I saw the signs and took it in for warranty repair. The starter clutch did not arrive on Friday hours before a trip departure. Dealer finally gave me a loaner starter which I had for a week. On the first start I noted how strong it was, and continued to be on every start hot or cold, no kick back. a week later clutch is there and starter is swapped out. immediate weak cranking, later hot start kickback.
I used to be in the camp of it must be the battery, cables or charging. not anymore with this brief experience. Still waiting to see if warranty will replace, BUT, it has to be completely broke before they do.
