Vance and Hines Dresser Duals
2010 CVO SG with the same exhaust head pipes, the heat shield on the front pipe was hitting the rear bracket for the floor board had to trim the heat shield. Wouldn't hit all the time. I would loosen the heat shield and adjust it away and it would work its way right back to the same location. To look at it, you wouldn't think it was going to touch the arm, but under acceleration, or sometimes even just idling it would. These motors move around a lot on the rubber mounts what looks like enough room sometimes isn't.
Buellrunner
Exhaust System Topics
09-15-2009 01:49 PM
