first 1000 mile service 2014 Road King - overfilled motor oil
Hey all,
New RK (2014) owner here. Just got my bike back from the dealer who did the first 1,000 mile service. I have a few questions.
The motor was filled with Syn 3 during the service. Oil level is at the max "hot" motor mark on the dipstick (Jiffy stand position) on a 'cold' engine. Clearly, it was overfilled. The owner's manual says "Oil level on a cold engine should never be above the midway point." The dealer says not to worry..."if it was a problem we would have seen it in the post-service test ride." Any worries about oil puking or excessive crankcase pressure when the bike gets really hot on a long ride? I can't imagine that the motor casing/oil was at max temp from the relative short dealer test ride. I tried to bleed-off a little oil from the drain but the dealer used teflon tape and an o-ring on the drain plug. I'd have to pull the drain plug completely...drain all the oil and then refill.
Also, the drive belt is very tight. I measured about 3/8" of belt deflection at the belt deflection window with approx 15 lbs of force. Per the manual, 3/8" is the minimum spec for belt deflection with a 10 lb force on the belt. I don't have the belt deflection tool, but I'm fairly good at estimating amount of force. I read somewhere about bearing wear when a drive belt is too tight. Given the relative newness of the belt, can I expect more stretch/less tension from the belt in the next 1,000 miles or so? ...hence, I should not worry about the belt tension and bearing wear at this time?
So glad I have tools and the shop manual for the RK. I may have the dealer do the next service just to document the service before the 2-yr warranty expires, or just invest in a lift table and do it myself. I did a fair amount of wrenching on a jack stand for my Fat Boy for ten years with no problems. Lastly, for the more complicated work, I could use the name/fon number of a good indy in Bucks County PA (about an hour north of Philadelphia on I-95) if anyone knows.
Appreciate any feedback...
Regards
Regards
Your oil level is nothing to worry about. 4 quarts with a new filter is the standard oil change. I have never had any issues whatsoever with 4 quarts and a filter. Dipsticks are not the gold standard of accuracy.
Without the gauge there is no way you can tell if the belt is over tightened. Before I bought my gauge I was certain my belt was way too tight. Guess what, it was spot on when checked with a gauge.
Have a beer and chill.
The monkeys at the dealer are not going to wait until every last drop is drained before they spin on a new filter and drop 4 quarts of oil in it. 4 quarts is what you put in a dry motor. They could care less that the motor is overfilled and oil is blowing out your air filter. They'll just say they all do that.
Do 3-1/2 quarts even when changing the filter and you'll be right where it should be.
