Tuner Question
Tuner Question
I have an 06 FLHTCUI with the 88TC. It is currently all stock with the exception of a set of V&H Big Radius pipes. I will be adding in the future, as funds are available:
95" Big Bore
Cam Support Plate
Cams
Head Work
High flow air cleaner
In many cases the progress will be add one part, and ride the bike for several months until funds and wrench time are available for the next mod. As such, my question is this:
Since the SC tuner for this model is no longer available, and I will be doing tune work between most of the mods, which tuner would you fine folks suggest I go with?
Thanks V
95" Big Bore
Cam Support Plate
Cams
Head Work
Thanks V
Thanks guys for the help so far. I also want to throw this in there. When talking to my dealership guy, he made the statement that I should find an used SE tuner somewhere, as when using others it is a matter of "when" you are going to have ECM problems, not "if". You thoughts on this statement?
