Changing 2014 brake lever
No pic, but you would want to put a piece of card board or something like a 1/4' thick in between the lever and the housing.
The lever being pulled just a little bit, prevents it from messing up the brake light switch underneath, while pulling out the lever.
BTW, you do need to split the housing to get the lever out.
I hope that helps.
Thank you.
FrankEGD
I hope that helps.
Thank you.
FrankEGD
I just pull the brake lever in and stick a piece of cardboard in between the lever and the switch so that the lever does not make contact with the brake light switch. My experience is removing the switch housing before you do this has a tendency to break the switch. It takes about 3 seconds. Do it first before you remove anything.
