Is the rear fender tip light supposed to work with the detachable tour pak conversion kit installed? Had it installed on my 15' and noticed the harness to the tip light is not connected nor do I see anyplace to connect it.
Just noticed the the tail light is not working either, so that and the fender tip light. I would "assume" these have to be disconnected since all the other lights are LED (both saddlebags and tour pak). Looks like a way for the moco to get you to buy all led.
Where should it connect? The fender tip light - I see the cannon plug (one loose end), but nothing to connect it to. The tail light - where should the cannon plug be for it? Under the seat?
fender tip light plugs into the tail light - there is also a plug for the tail light inside it from the rear harness - if you paid for the install just take it back.
