Clutch issues
Clutch issues
I'm looking for some help with a couple of clutch issues. I have an '7 FLHX with 115,000 miles. I put in a new 103 5,000 miles back along with the SE clutch pack, and a bunch of other pieces and parts. While I thought I got all the old plates and frictions out of the old stack, when I adjusted the clutch the adjustment screw in the center of the clutch (behind the derby cover) was out much farther than it has usually been. I dismissed it as being new/different and put the cover on. I found that I had about half of the lever travel and it pulls up hard, like something is in a bind. The clutch functions OK, but just barely. I rode it to Sturgis as a break in/test ride thinking maybe it had to "wear in", but no change.
The second thing I have noticed is the free play in the lever changes if on or off the throttle. It tightens up and loosens up as I apply and back off of the throttle. Never noticed that before. I do notice some bearing/gear whine idling in neutral that goes away when I put it in gear.I replaced the primary output bearing with the motor swap, but have yet to go into the transmission.
I'm ready to change the engine oil and filter (5,000 miles) and could certainly do a little investigation if I kinda knew what to look for. Any help would be appreciated. Thanks.
It installs so that the pressure against the plates is increased as the bolts are tightened, correct? Same as the old one came off. The center is high before the bolts and retainer ring is torqued?
Maybe I should (or should have) compare the complete plate packs for total thickness. It's due for oil change so it'll be on the lift anyway.
Do you mean the thin fibre disc with the smaller spacer? Yup. Maybe narrow is a better term. Spring seat? do you mean the outer pressure plate? Well now I got to go look at what I took out. Stay tuned, and thanks for the suggestions.
dstull2207@gmail.com
08-02-2016 07:45 AM
iamawakenowtvm
04-26-2014 01:58 PM
