How many of you use chrome polish?
Old 09-29-2014, 02:41 PM
groupw's Avatar
groupw
groupw is offline
.......... we're s'posed to polish the chrome ?
Old 09-30-2014, 09:03 AM
47Norton's Avatar
47Norton
47Norton is offline
Thumbs up
I never believed in chrome polish. I thought whatever I was waxing/polishing the bike with was good enough. Then I tried Mother's chrome polish and I can definitely see a difference. Seems to give the chrome kind of a blue luster.
Old 09-30-2014, 09:14 AM
4_stroke's Avatar
4_stroke
4_stroke is offline
Usually polish is abrasive and removes contamination from the surface, wax seals the surface, they do too different things. I use polish to get the shine and wax to keep surface sealed from the elements. I always wax, or oil on the chrome to prevent oxide from forming under the surface and causing it to flake off.
Old 09-30-2014, 09:54 AM
Retrop's Avatar
Retrop
Retrop is offline
Chrome polish will take off any burnt on bugs, crap or debris with a little rubbing.
Wax, on the other hand won't. If your chrome is absolutely clean, wax is all you need. If not, use chrome polish.
To see if your paint or chrome has any impurities on the surface, do the plastic bag test: Put a baggie on your hand and rub it on your paint or chrome surface. If you feel anything, your paint or chrome is dirty and needs attention. If it is as smooth as a baby's rump, your good.
Old 09-30-2014, 09:58 AM
RickDM's Avatar
RickDM
RickDM is offline
I like to use cheap Turtle Chrome polish on a wet micro fiber cloth every 3 or 4 months to gently remove road tar and grime from my pipes.
Old 09-30-2014, 01:08 PM
Rush Racing Products's Avatar
Rush Racing Products is offline
We designed a chrome polish with an acrylic sealer. Helps protect the chrome from corrosion, especially near the coast where salt water is an issue. If you see our reps at an event we usually give out free samples.
Old 09-30-2014, 03:26 PM
bklynbob's Avatar
bklynbob
bklynbob is offline
Default Mothers
Rode under a new concrete overpass last week. They were irrigating the newly poured concrete and i went through the sediment. The diluted concrete dried and stained my chrome wheels. The Mothers chrome polish got the stains off and the wheels look better than new,but it did take 2 applications and a lot of elbow grease.
Old 09-30-2014, 06:47 PM
powerman1972's Avatar
powerman1972
powerman1972 is offline
The only stuff i use on chrome is Flitz! I tried the rest and stuck with Flitz!
Striker951
04-02-2022 05:05 AM
foxtrapper
05-24-2013 09:50 PM
Jd Swiper
08-30-2012 10:37 AM
Bigpoppa_Junior
General Topics/Tech Tips
11
02-10-2010 08:36 AM
so165
11-09-2006 12:30 AM
Quick Reply: How many of you use chrome polish?
