push button alarm bypass?
my buddy has the push button style alarm on his 06 electra and i helped him set a new bypass code. that was no problem, the problem we are having is when trying to access the bypass to enter the code.
want to make sure we know how if the need ever arrises.
the instructions say to turn ignition to on and immediately hold down both turn signals till the zero and four dashes appear. that doesn't happen all we get is a screaming alarm and hazards on.
Stand next to bike
With ignition off and run/stop switch set to run
Press and hold left turn signal with left thumb
With right hand turn on ignition and move right hand to right turn signal and press
Release both turn signals
Location: Western Illinois, land of bad roads, and corrupt politicians
You have to push the button to activate or disarm the system with the older manual FOB.
Here's the way to do it with the manually activated system
Turn the ign switch to accessory,
QUICKLY hold down both left and Right signal switches until the key
lamp flashes rapidly, enter the
first digit on the left And use the right as an 'enter' key,
enter all five digits of the
passcode and the system will Disarm, if you screw up, the
alarm will activate and you will have
to wait ten minutes.
So as an example, if your code was 12345..................
Ignition to accessory.
Quickly press and hold both signal buttons until the key lamp flashes.
In order:
left 1 then press right
left 2 then press right
left 3 then press right
left 4 then press right
left 5 then press right
System should disarm
