Finally did my breather bypass (pics included)
Old 02-27-2017, 06:30 PM
checkers's Avatar
checkers
checkers is offline
Cozz, I ran 1/4" 90 degree elbows from both breather bolts behind A/F next to front pushrod tube, venting side by side out of frame tube below oil filter. I cut both lines below frame at an angle to draw crankcase vapor out of tubes at speed. No sludge in lines after a year of riding. Yes two separate 1/4" vent tubes side by side out the bottom, no catch can or filters. I used zip ties at all clean connections. It is subtle.
The following 2 users liked this post by checkers:
Cozz (02-27-2017), rocket23 (04-12-2017)
  #482
Old 02-27-2017, 06:36 PM
checkers's Avatar
checkers
checkers is offline
Originally Posted by golfblues
"Anybody else found some of this brown goo in their breather system?"
That's what you're supposed to find in your system. I have a clear liquid at the bottom of my catch can but if I squeeze a paper towel on the sponge its brown crap
If system is scavenging or breathing enough, it should exit tube(s) without collecting in tubes. Short trips or running in colder weather can add to this issue.
Cozz (02-27-2017)
  #483
Old 02-27-2017, 06:41 PM
golfblues's Avatar
golfblues
golfblues is online now
Received 1,434 Likes on 874 Posts
Could be a kink or low spot in the line thats holding it in.
  #484
Old 02-28-2017, 06:26 PM
checkers's Avatar
checkers
checkers is offline
That's another possibility.
  #485
Old 02-28-2017, 07:13 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,232 Likes on 1,810 Posts
... I cut both lines below frame at an angle to draw crankcase vapor out of tubes at speed. No sludge in lines after a year of riding. Yes two separate 1/4" vent tubes side by side out the bottom, no catch can or filters. I used zip ties at all clean connections. It is subtle.
"Back in the Day" (in automotive applications), those were called Road Draft Tubes...before PCV
  #486
Old 03-01-2017, 07:33 PM
checkers's Avatar
checkers
checkers is offline
"Zackley" same theory, same design. I didn't think anybody on this forum was old enough to know what a draft tube was or a "slobber tube"
  #487
Old 04-11-2017, 08:25 PM
rocket23's Avatar
rocket23
rocket23 is online now
Received 3,596 Likes on 2,852 Posts
breather bolts came in I'll post pix in a few days
  #488
Old 04-12-2017, 05:25 AM
NELS's Avatar
NELS
NELS is offline
On the 50's era Chevy's and Buicks the draft tube had a mesh screen that would clog up and we used to heat them up with torches to get them to vent again. Yes! some of us are old enough (G)
  #489
Old 04-12-2017, 06:34 AM
multihdrdr's Avatar
multihdrdr
Damn...you're old
  #490
Old 04-12-2017, 08:01 PM
checkers's Avatar
checkers
checkers is offline
Damn...you're old
Nels nickname is "Dirt"
Quick Reply: Finally did my breather bypass (pics included)
