Finally did my breather bypass (pics included)
#71
here are pics of my ventilator mod. you can see the orange high temp silicone in the holes. Not all breather backplates are the same though. https://www.dropbox.com/sh/coknme8pw...9-6Um1xea?dl=0
2010 Limited with some stuff
#72
SE Ventilator cause I like the way it looks and I already have it installed. With the K&N filter, flows 287CFM which is fine for the heads I have which flow 252CFM
(2) Dorman 785-410 1/8" MNPT - 1/4" hose fitting (advanced auto)
(10') 1/4" vacuum line (advanced auto) yep plenty left over.
(1) 1/4" vacuum hose "T" (advanced auto)
(1) 1/4" to 3/8" vacuum hose adapter (advanced auto)
(1) Spectre 3991 Breather Filter (advanced auto) http://shop.advanceautoparts.com/p/s...m=spectre+3991
total - $15.49
took the backplate and drilled 25/64" holes in it
Then I used a tap, M10x1.25 to thread the holes
Then I cleaned the breather holes and oil drain holes thoroughly with brake cleaner
Then I siliconed the oil drain holes that go back into air intake (yep that was the only color hi-temp/oil resistant silicone I had on hand.
Then I screwed in the fittings, attached hoses, attached clamps, inserted "T" in proper location, ran the hose inside the front pushrod tubes, and located the filter just behind my oil cooler and fastened in place with a zip tie. The "wetness" you see in that last pic is from my cam change a couple of days prior to this mod.
all said and done, $16 in parts and about 45 minutes of my time that will prolong the life of my motor.
Wingsfan (05-06-2016)
#73
#74
Super Clean set up you built!
Just to clarify, we have air cleaners that have the external breather system built in for as little as $148.95, and we have a variety of external breather systems that work with many other air cleaners besides ours. They range in price from $29.95 to 49.95.
You can see them all HERE
Ultra Limited? Also which breather kit would work best with stock air cleaner?
Thanks
#76
here's the rest of the information that goes with the pics above from a previous post of mine for you guys that want to do this. it really is easy to do.
total - $15.49
total - $15.49
#77
#78
sleepymonkeyheritage (09-26-2022)
#79
I used JB weld to fill the tubes going to the A/C first because the holes I drilled and tapped were going to intersect them,Then used JB to permanently seal the fittings,Then used a round file to clean up the inside bolt holes.
#80
Received 3,941 Likes
The Discrete Head Breather System at this LINK will fit.
