36mm Rear Axle Nut Wrench
There are multiple versions of a 36mm box wrench on the market. Some have a 3/8" square cut out for a torque wrench and some have a 1/2" square cut out for a torque wrench. There's a significant difference in cost between the two. My question: Has anyone successfully applied 95-105 ft lbs of torque (spec according to the manual) to the rear wheel axle nut when reinstalling the axle using a 3/8" torque wrench? Or can it be accomplished by using a 1/2" torque wrench with a 1/2"-3/8" adapter on the wrench?
I can't be the only person that has asked this question however my search of this forum came up empty. Any input is appreciated.
I have a Kobalt 36mm socket that's a 1/2" drive that I use. Bought it at Lowes. My experience is those adapters are lousy when applying high torque. I bent the crap out of one applying 140ftlbs of torque to a compensator bolt. I also think the adapter might interfere with a correct torque reading.
When using an adapter or crows foot, the torque will be accurate if:
1) you use the torque wrench at right angle with the adapter length (length of the lever is unchanged).
2) if you measure the distance the adapter adds to the end of the wrench (lever length is extended) and use a formula/chart/online calculator to adjust the torque accordingly....
