witch custom dynamics?
according to the custom dynamics website I think you would need this kit
GEN200-KIT-BCM
I have a 2013 Street Glide, one of the first mods I did to my bike was to add custom dynamics led's, very easy to install and they are very bright.
Go to the website and check them out http://www.customdynamics.com/
Take a look at the kit part number I listed and make sure its the correct kit for your bike
If you have any questions give them a call.
Hope this helps you out, Enjoy!!!!
GEN200-KIT-BCM
I bought individual items, not the kit. I wanted the Dynamic Ringz instead of just replacement turn signal lenses for the front. Here's the part numbers that I ordered:
1 Dynamic Ringz Bullet LED Turn Signals 1157 GEN200-AW-1157 $79.95 $79.95
1 Genesis Bullet LED Turn Signal Red 1157 GEN200-R-1157 $69.95 $69.95
4 Bullet Lens HDBULLET $1.95 $7.80
Installation was a piece of cake, remove the lens, remove the bulb, install the LED unit's bulb base in place of the bulb, replace the lens. 30 seconds per bulb and they work great.
Received 8,249 Likes
For the rear:
Bullet Style Turn Signal LED Inserts Red 1157/dual intensity (BCM Compliant)
Item: GEN200-R-1157
For the front you have three choices:
Regular amber
Moonshinez - Solid white cluster that flashes white on turn
Dynamic Ringz - White halo outer ring when riding normal. Amber inner cluster that flashes when on turn. White halo turns off when in turn mode as well.
Item: GEN200-R-1157
Regular amber
