lowered front end
But due to the angle of the shocks, that "inch" shorter only nets ¾" drop.
Nope, all harleys air shocks are 12 3/4. The have been for decades. Except of course the lo profile 12's. Grab a tape measure if you don't believe me. I just assumed that's what you meant. But we all know what happens when we assume......
We drop front ends all the time here. Our two biggest sellers are the Progressive drop in lowering kit and their mono tube kit. The drop in kit will drop it 1" to 2" without having to tear apart the whole front end to give you a lowered ride which is great. People that are looking for a lowered stance but also an improved ride will usually go with the mono tube kit. Not only are you able to still drop the bike 1" to 2" but you will get an amazing ride from it as well.
Ok...
Sorry...I was thinking the Progressive cartridges. It was late and I wasn't reading it correctly.
Not sure what you mean??? The drop in kit is just a set of 2 shorter springs, two stabilizer springs, and cuttable spacers. The oil is critical is dampening.
I think all he was saying is the stock shocks are 12 3/4 inches, not the 13 inches we all are guilty of calling them. So swapping from stockers to the 12 inch Low Profile shocks will only net you 3/4 of an inch drop, not an inch.
Yeah, both of the ones I bought were the 1 inch shorter stands. Gets a little expensive trying to find one that will work , thus the wedge to solve the problem. I agree, ten minutes to change the stand with a beer break in between.
Many motorcycles allow you to measure the bottomed out clearance readily enough by simply removing the springs from the fork tubes and jacking the front wheel up until it bottoms. Not sure if this is the same with a Harley or not.
