Question on Belt Tension
when checking the tension, do you check it on a lift, or on the ground?
I swear the manual said on a lift, and now I am concerned that I may have over tightened the belt. I last adjusted it on a lift, and noticed that when I put the bike back on the ground, the belt was tighter than when up on the jack...
I've developed an inner primary leak, and just learned that too tight of a belt can cause a leak.
since the manual said to adjust the tension with the rear wheel off the ground, at the time I wasn't concerned about the tightness of the belt when back on the ground.
I gotta double check when I get home, but in the rear wheel removal section, it has you checking the belt deflection with the wheel off the ground...(if I recall correctly...I could be all wrong, and messed up)
Received 4,614 Likes
My manual also says lift the rear wheel, but just so you can spin it and find the tightest position on the belt. Then put it back on the ground and have an assistant sit on it while adjusting the belt. That's about as far as you can get from adjusting it on the lift; I'd check that deflection on the ground right away. I wouldn't be concerned about the belt as much as putting too much load on that outer bearing for the transmission shaft.
Do it to what the Harley Service manual says for your year and bike. Bikes and year models are different. My Softail says to do it loaded with rider. Depends on design. Use the proper gage and forgot rolling and all the other suggestions. You really would need to get it way tight to hurt a seal or bearing. Since your swing arm is bolted to your engine, it all hangs together and is probably why the manual says what it says and there is little difference when it moves with the suspension. On yours hanging, sitting or you on will probably show little difference. You check it out and report back. A Softail swingarm is a tad off center and moves independent from the engine, so that is why it is different. I lay over mine and set it. I forget right now but when I am off it, it changes about the tolerance in the setting. However you need the manual if you are going to set it. I got my gauge off Amazon. I checked it on a scale and it's close. Made by Motion Pro 08-0350. About $20 and free shipping now.
