What plugs is everone running?
10-22-2014, 04:08 PM
Going to do new plugs just curious what everyone runs for plugs?
10-22-2014, 04:37 PM
H/D Plugs.
They are the only thing that you can get from the dealer that is reasonably priced and as good as you need them to be.
10-22-2014, 04:39 PM
From everything I have read spark plugs make next to NO DIFFERENCE in performance regardless of how much you spend. I just installed the least expensive plugs that Harley makes - $8 a pair I think.
10-22-2014, 04:41 PM
my dyno tuner was pretty adamant about only using Harley plugs.
10-22-2014, 05:03 PM
Stock Harley as well.. you can introduce other issues with the knock detection and such if you use the wrong kind. My mechanic used stock ones as well.
10-22-2014, 05:04 PM
Champion RA6HC ,one step cooler than the stock HDs and about 2 bucks a piece at O'Reilies.
10-22-2014, 05:12 PM
Quote:
Originally Posted by
bwoltz
Would 1 step cooler help with the occasional detonation we sometimes get on hot days?
10-22-2014, 06:47 PM
dforeid
I'm not an expert by any stretch..
But since that is pre detonation, or detonation before the spark, I don't see how it would help.
10-22-2014, 06:56 PM
I've always used OEM spark plugs on all my engines.
10-22-2014, 07:00 PM
blackflame
Stock OEM plugs, stock OEM plugs, did I say stock OEM plugs? PERIOD!
