How many miles on a full tank
I'm sure this has been covered many of times but I couldn't find any exact threads.
I Know that the fuel gauge isn't completely accurate but I've started measuring the mileage between fill ups. Today, I filled up and got approximately 165 miles since my last fill up. This was mainly hi way riding while using cruise control at about 70 MPH. I don't have anything special on the bike, just the an air cleaner and Rinehart mufflers.
I'm not sure if 165 miles is in the normal range. A buddy told me that he gets about 145 miles between fillups but he has an older touring bike.
Thanks
Thanks
This is what Im talking about. The gas light didn't come on but the needle on the gauge was so close to empty. There's a difference with the needle when riding vs. when idle. Since it was nearly on top of E, I pulled into a station. Guess I could have gotten more, huh.
I can get over 200 on a tank, and put about 5 gallons in at a fill up. Last tank was at around 220 miles, and filled just under 5 gallons. That was cruising, not in town riding.
In town, I fill up at around 180 or so.
When my fuel light comes on, I usually have a tad over a gallon left in the tank.
I have did the math on every tank I have put in it for over 9K miles, and this has basically held true throughout.
Set your trip odometer to zero when you fill up, or note the mileage if you don't have a trip odometer. Next fill, divide your miles driven by how many gallons you put in. That will give you your miles per gallon. Take that times your tank size in gallons, and that's how far you can go before you are pushing your bike.
Why is that so hard for people to figure out? Your miles per tank is meaningless. Some have five gallon tanks, some have six. Some Sportsters have much less, but get much better mileage. Did you have a tail wind or a head wind? That can easily make a difference of ten miles per gallon, or 50 or 60 miles per tank? Anything over 60 mph and wind resistance enters into the equation. Are you running your engine in the torque band, or are you lugging it? Are you riding in the mountain hills of Colorado, or at flat zero elevation on the coast?
