Heated Grips Failing?
Old 10-24-2014, 08:24 PM
Rustrtal's Avatar
Rustrtal
Rustrtal is offline
Mine only lasted 2 Months and were replaced. Been working fine since.
Old 10-24-2014, 08:48 PM
themensh's Avatar
themensh
themensh is offline
OK...I live in Florida...don't have no fancy heaters on my hand grips....but when the temp gets below 60, I put a couple of those 'toe warmers' you buy in the outdoor hunting section of walmart, into my glove. A pack of them costs like, six bucks. Put two into your shoes.....toasty warm for about 6 hours. Only need them about three hours because by then, it warms up to over 65...they do nice in a back pocket also. Just saying, in case you are near a walmart and your fancy handgrips don't work.
Old 10-25-2014, 09:32 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,410 Likes on 880 Posts
Originally Posted by themensh
, I put a couple of those 'toe warmers' you buy in the outdoor hunting section of walmart, into my glove. .
Yes, I've been using those hand warmers in my gloves on cold mornings for a couple of years, but it's time to find a permanent solution.
Old 10-25-2014, 10:22 AM
cass's Avatar
cass
cass is offline
I just had my grips replaced for my 2013 FLHTK, factory warranty just under the two year mark. they failed earlier in the year but I just had them replaced at 25000 mile service. Zero $$ was good for me. they tried replacing one, but it didn't work so they had to replace the other one too.... now they work great.
Old 10-26-2014, 08:03 AM
troop's Avatar
troop
troop is offline
Gonna install some heated grips when I put on some WO 578 bars. Think I'll try some Avons but still sounds like failures are pretty common....
Old 10-26-2014, 08:13 AM
jdvorchak's Avatar
jdvorchak
jdvorchak is offline
Mine are still working on my 2010 FLHTK with 25k miles and I've never been above 2 on the setting. I wonder if the guys with the failures turn them all the way up to "get 'em warm faster" then reduce the setting? Still they should work turned all the way up all the time for them to be considered reliable.
I used to own an GL1800 and heated grip failures were rare as I remember. Lots of heated seat failures tho on the 1800.
Old 10-26-2014, 09:09 AM
cass's Avatar
cass
cass is offline
most of the time, I seldom went above 3 on the settings. I do a lot of early morning riding during the fall commuting to work. I crack them when it gets down to 55 or so, along with my electric liners....just in case.
Old 10-26-2014, 09:16 AM
NiteOwlNY's Avatar
NiteOwlNY
NiteOwlNY is offline
Mine failed within the first month of owning the bike, I had the dealer replace them and these seem to still be working...
Old 10-26-2014, 12:35 PM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
installed 4 or 5 yrs ago no problems, set to 2 or 3 ,got the nostalgic (plain) ones after someone I know got the metel desighned flames ones and the metel would melt the grips and make them all sticky and melt,big mess and he removed them.
use them regularly,way convenient as others have said.Maybe the failures all live in alaska ? Pa its warm all year.
Old 10-26-2014, 01:30 PM
harleyboy63401's Avatar
harleyboy63401
harleyboy63401 is offline
Still working on my 10 LTD @ 43,000 miles...never higher than 3...generally on 1 or 2 ! Put them on my wife's Strret Glide...failed in first 12 months...fixed under warranty and good up to now. She is pretty hard on them...slightest chill she has them on!
I like them and probably won't be without again!
Quick Reply: Heated Grips Failing?
