Clutch Cable length for 18in apes?
Old 10-24-2014, 08:49 PM
sharpshooter's Avatar
sharpshooter
sharpshooter is offline
Default Clutch Cable length for 18in apes?
Im going with 18's on my road king.. Who here has a good idea on the length of cable im gonna need?
Old 10-24-2014, 10:29 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
+8" should do the trick.
Old 10-24-2014, 10:34 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
I did +8 for 14" bars so I would prob try going 10 or 11". Mount the bars, then take a measurement from the clutch hub going into the tranny following a nice curve all the way up to the grip. Move the bars back and forth making sure it doesn't get too tight. Hill Country Customs have a good quality product. I would call them and give them the measurement. Minus the stock length from the new measurement and you'll know how much more cable you need. I'm still thinking 10-11" should do it but, the bars you use make a big diff.
Old 10-25-2014, 01:16 AM
billd's Avatar
billd
billd is offline
16" apes on my 2014, did stock +8 on clutch. New Brake line (ABS) was 2 sections with connection inside light housing.
Old 10-25-2014, 03:47 AM
Warbird40's Avatar
Warbird40
Warbird40 is offline
+12! I put 16's on my King with a +10 and its "good" when handlebars are turned completely....I would do +12, JMO.
Good luck
Old 10-25-2014, 07:34 AM
crimson13's Avatar
crimson13
crimson13 is offline
I just did 16" apes on my 2014 RK I went with a plus 10, I have enough cable to go 18s if I want. I went with HD Diamondbacks. plus 10 would be good for 18s.
Old 10-25-2014, 08:41 AM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
Question for all of you, are you using the P clamp on the fork to secure the cable? My cable lays much better without it, Just curious what others are doing with it.
Old 10-25-2014, 12:23 PM
Warbird40's Avatar
Warbird40
Mine is thru p clamp and ss clamps on the handlebar
Old 10-25-2014, 12:29 PM
Northbound Southerner's Avatar
Northbound Southerner is offline
Depends on how you route it. I have done 18s. If you go the stock method, you can get by with +8. I like to run mine down the frame and under so I will usually do +12.
Old 10-25-2014, 06:14 PM
sharpshooter
I was thinking +10 so you guys think 12 would be better then. Whos got the best prices?
Quick Reply: Clutch Cable length for 18in apes?
