Wheel bearing question
I'm looking at a 2014 FLHX front rim and rotors for my 2012. It's from an ABS bike so I know the bearings need swapping as mine isn't ABS. Does anyone know the actual bearing # and do i need the complete bearing kit from Harley (with spacers etc) or just pick up the bearings? Are there better bearings than others?
Thanks!
Thanks!
HD wheel bearing part number 9276A (non Abs). I don't know if they are better but you can get a set of All ***** Bearings a little cheaper. I don't think you will have to have new spacers only the bearing swap.
http://partsfinder.onlinemicrofiche....-WHEEL---FRONT
The non-ABS bearing is a widely available stock bearing, available from any bearing outlet, no need to buy a 'Harley' one. The existing normal bearing in your wheel has the universal ID engraved on it, so as you are going to replace it, as per DD's advice, just take it out and to a local shop - an auto parts store may be able to supply them.
The tire /wheel combo I'm buying is a take off with 4 miles on them. Bearings shouldn't be worn just yet.....that being said, I'll probably pick up a pair.
The axle sleeve (inside the wheel) is the same for ABS/Non ABS. I'd PM Low Country Joe for more specifics but I'm thinking you can just pull the left side bearing (for front wheel, right for rear wheel) and install the non ABS bearing. The left side bearing always goes in first (for the front wheel) and gets seated all the way in the cup. Then the right side bearing is installed and seated just enough to take the play out of the axle sleeve but not binding the bearings.
On the rear it's the right side bearing that goes first.
I'm sure I've missed something but like I said, I've only done 3 or 4 ABS/Non ABS bearing swaps. Joe is a good wrench and is rarely mistaken as I sometimes am.
"it's not a matter of taking up space" what else is a spacer about?
If the OP is putting a ABS wheel in a non ABS bike, and the ABS bearing is 5mm wider ( you number) then take 5mm off the spacer that was on the non ABS wheel. should bolt right in and the speed sensor doesn't mater.
