Stage 1 or stage 2
We offer a couple options, a stage 1 performance package that includes a complete true dual system, arlen ness big sucker intake and a Dynojet power commander 5 with a map loaded for $1089 which will give you up to 12 ft. lbs. torque gain or a set with high performance slip ons, power commander and big sucker for $699 (up to 7 ft. lbs torque gain) Other options available, call for details (661)951-9878
My RK has a stage 2, 95ci big bore kit and the power difference compared to my friends 88ci is very noticeable. If you are planning on keeping the bike for many years to come, I would invest on the stage 2. But if you like to change bikes every couple of years, stage 1 is my recommendation.
Good luck.
Good luck.
alot of us are running around on under $500 stage 1's...some pay over $2k for stage 1 ( drop it off at the dealer and full retail...") a stage 1 will get you 7 to 10 horsepower.( this is simply by removing the restrictions to flow in the stock intake and exhaust which are part of the emissions control)
reliable and retains MPG
Most of us will have an exhaust system with no cat, either replacing the headers with aftermarket or decatted from ebay ( $150) or cutting and welding ours.( whethr we
just about all the hi flow intake kits will potentially flow more than the motor could ever demand- the value leader is the ness big sucker with chrome backing plate- about $120 on ebay from easternpc
a "stage 2" is generally adding cams and good for another 10 hp or so ( again look at dyno curves) reliability may be affected as will MPG depending on the parts chosen.
if we use any unfamiliar terms, post back with questions
Mike
I can't be messing with 'stage' this or that! Mufflers air filter and cam plus a decent tuner will give worthwhile improvements. A stock EPA bike has quiet mufflers and airbox, which everyone knows about, but it also has compromised ignition and cam timing. It's worth sorting them all out in one go.
