CB on the HK radio...separate unit?
The stock HK radio on my 2012 limited is starting to cut out. I might buy a take off instead of having it repaired. What I want to know is that is the CB built into my radio? or is there a separate CB unit? It has been a while since I had the faring off and I don't remember. Thanks
CB Unit is separate from the radio as already stated. Works through the HK radio.
Quite common for HK radio circuit boards to crack. Symptoms are loss of sound until the radio is shut-off and turned back on. Iron Cross Radio can fix you up fairly reasonably and tell you what to do to stop this from happening again. Check the brackets inside your fairing and make sure they aren't broken.
Both brackets plus his speaker supports were broken.
Replaced the fairing brackets with the "Strong Arm Fairing Support." Lifetime warranty and a cool looking orange color.
His fairing shook all over.
Mine are fine but it will be a winter project.
Cheaper than two Harley supports.
