So I replaced the batteries in my fobs....
Old 10-31-2014, 10:19 AM
Nute's Avatar
Nute
Nute is offline
Not looking to get flamed but could you possibly have installed the batteries backwards (upside down). Also, put a Volt meter on the batteries and make sure you have 3 Volts.
Old 10-31-2014, 11:51 AM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,300 Likes on 780 Posts
Electronic devices typically don't like the negative and positive reversed. It's quite possible you ruined both FOB's by putting the batteries in backwards.
Old 10-31-2014, 02:55 PM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
Keep one Fob in the house. I had both fobs with me & the bike would not start. I retuned one to the house & moved my bike a few feet & it started. There is a section in the manual about electrical type problems from , say power lines etc. Good luck. Hey, let's know what solved the problem.
Old 10-31-2014, 03:29 PM
Six7One's Avatar
Six7One
Six7One is offline
Are you sure they are the same battery? A 2025 and 2032 are very close in size. But the 2025 is a little thinner if I recall.
Old 10-31-2014, 03:35 PM
stic2it's Avatar
stic2it
stic2it is offline
Flip the battery over, they are probably upside down
Old 10-31-2014, 04:06 PM
ddm502001's Avatar
ddm502001
ddm502001 is offline
Last ride we took as a group one fella had replaced batteries and had to hold the fob against the radio to make work, had the wrong batteries in his. There is a series of those style batteries, incorrect in 1.5v and the correct units at 3v, he had purchased the wrong voltage type.
Old 10-31-2014, 04:33 PM
Tirpitz's Avatar
Tirpitz
Tirpitz is offline
You might also trying reprogramming the FOB's to the bike. I think you have to have the FOB close to the bike and turn the key to the start position and then shut the bike off just after the security system arms. Its worth a try.
Old 10-31-2014, 04:56 PM
RoadHog659's Avatar
RoadHog659
RoadHog659 is offline
Any chance you accidentally flipped the Run/Stop switch?
Old 10-31-2014, 05:00 PM
ch54's Avatar
ch54
ch54 is offline
Got it fixed. Feel kinda dumb. The little metal tab was bent the wrong way. So simple. Thanks forth help.
Old 10-31-2014, 05:37 PM
Sam D.'s Avatar
Sam D.
Sam D. is offline
That's okay,,, you took one for the rest of us, lol... don't feel bad.
My FOB's are now 14 months old and I'll be changing the battery in both...
Quick Reply: So I replaced the batteries in my fobs....
