2008 Street Glide, 30T pulley and Cruise Control question
Hi Everyone,
I've got a 2008 Street glide that I'm rebuilding the primary and trans on as it has a noise that is speed dependent. Hopefully the tools should turn up today so I can start pulling the trans apart.
I've been thinking for a while about changing the trans pulley to a 30 tooth unit to make 2 up hill starts a bit easier. I plan on using the Triglide pulley #83595-11. I realize that using this pulley and keeping the stock tooth belt I may have to elongate the rear axle hole.
My concern is I'm using a SEPST and speedo recal can't be done using this unit. I plan on getting a Dakota Digital SIM 1 to correct the speedo. Has anyone had problems with loosing their 6th gear light and cruise control?
If anyone has done the same or knows a better way can you please help.
I've done a lot of reading/searching but I'm more confused/muddled up than at the start!
Thanks in advance.
Thanks in advance.
I respectfully disagree as pulley changes can cause 6th gear light and/or cruise to be inoperable in throttle by wire bikes with an ECM. This can be corrected with certain tuners such as the PowerVision.
2010 Limited with some stuff!!
I have an 08 and changed gearing and lost the 6th gear light prior to regaining it back with the TTS. I believe it to be an anomaly with my cruise as I did not lose cruise when I went to a 30 tooth and others using the same setup lost theirs. I have since changed out the 30 tooth for a ring gear conversion.
Hi Everyone,
Thanks in advance.
Thanks in advance.
If I'm thinking correctly this gearing change would make the normal error worse. So I would say forget the SIM-1
calibration
I tried in vain to use one of the after market calibrators. In fact I tried three of them with the same results. No good. I could calibrate all day long but the 6th gear light and cruise light wouldn't work. I went to a TTS tuner and it had the ability for calibration . It worked great. At the time I had a SERT on there was originally made by TTS. They offered and upgrade to TTS . I sent them my tuner and they upgraded mine. The problem was solved. Speedo and calibration was and is right on now.
Did Not Affect Mine
Like the OP, I used the 83595-11 TriGlide pulley, and changed the belt to a Goodyear 39T belt to alleviate having to mess with the OEM rear axle adjustments on the '10 Ultra.
I did not experience any effects with either the 6th gear indicator or speedometer calibration. I will say I was nervously expecting issues with one or both.
Good luck.
