Utra Classic or ultra Limted?
I've started shopping for a new 2014 or 2015 ultra for Christmas this year. Santa (me) decided I've been damn good! I can't find a list of all the differences between the limited and the ultra anywhere? I will be getting ABS and 6.5 screen but no real need for heated grips in south Florida and not sure on water cooled. What other changes are there between the 2 models? does Harley (or anyone) put out a complete list anywhere?
Thanks!!
Thanks!!
The twincooled motor has higher compression and makes better power right off the floor.
so factor than into your calculations
from Rider magazine:
"On Jett Tuning’s dyno, our 2014 Ultra Limited test bike belted out 95.0 lb-ft of torque at 3,700 rpm and 79.2 horsepower at 5,200 rpm at the rear wheel—11.5 percent and 16.3 percent higher, respectively, than the standard Twin Cam 103-equipped 2011 Road Glide Ultra (85.2 lb-ft of torque, 68.1 horsepower; Rider, September 2010"
Mike
Mike
Web site sucks
Based on the compare models once I add security and upgrade infotainment the major difference is the Ultra Classic has "15.0" radio presets where the Limited has "15". The site tells me less about the difference of the 2 bikes than my granddaughter does and she's into ponies. Hell compare doesn't even list heated grips
Security option $395 and Premium radio $795. Heated grips. The big difference is Twin Cooled. If you think you need it get it, but they've been building air cooled bikes for quite some time. Twin Cooled would neither make the deal or break the deal for me, but then I basically NEVER ride in traffic. Oh and the limited has the rack on the Tour Pack. ($129). Does the upgraded radio on the Ultra include CB ? (something else I'd never use)
What "guards" are people talking about ?
Maybe this will help?
2014 Electra Glide Ultra Classic MSRP $23,249
High Output Twin Cam 103 powertrain
Hydraulic clutch
Boom! Box 4.3 infotainment system
Jukebox media compartment with USB
New Batwing fairing with splitstream vent
Stiffer 49mm forks
Daymaker LED headlamp and fog lamps
LED rear lighting on Tour-Pak
Impeller cast aluminum wheels
Restyled Tour-Pak with One-Touch latch
Restyled saddlebags with One-Touch latch
One-Touch fuel door
Low-profile front fender
Larger gauges with improved graphics
New intuitive hand controls
Reflex Linked Brakes with ABS
2014 Ultra Limited MSRP $25,899
Twin-Cooled High Output Twin Cam 103 power train (wet heads)
Hydraulic clutch
Stiffer 49mm forks
Boom! Box 6.5 infotainment system
Gloss Black inner fairing
Contrast Chrome Impeller cast aluminum wheels
One-Touch fuel door
CB Radio
Hydraulic clutch
Stiffer 49mm forks
One-Touch fuel door
Hydraulic clutch
Stiffer 49mm forks
One-Touch fuel door
CB Radio
