Street Glide - brake light & rear blinkers don't work HELP !
I have a 2010 Street Glide.
Standard rear set up, except for changing the rear blinkers to clear lenses with red bulbs a couple years ago.
I never changed any modules or anything with the tri-bar light.
I noticed yesterday that my brake light & rear blinkers don't work.
Rear running lights are on at start up as usual, and my front blinkers work.
Blinker indicators on dash work.
Horn and Cruise both work as well...
Any ideas as to what it could be.
Any help would be greatly appreciated.
Thanks Boys...
Thanks Boys...
I am assuming you don't have the center rear tail light?I believe your brake and signal lights are fed to the tribar light.In the tribar light the brake and signals are combined and sent to the bullet lights.You might have a bad connection on the inp(left side)or oup(right side)of the tribar light,or the circuitry in the tribar is defective,or the wiring from the tribar to the back of the bullet lights.Or it might be as simple as a fuse being blown.
Your tri-bar was a running/brake light?Did you check the connectors on the sides of the tri-bar light?
tri-bar is the 3 strips of lights at the bottom of the rear fender on a Street Glide
the bulbs? uhhhhhh.. I don't think so.. . maybe ??
I can't remember if the tri bar lights up as a brake light or if its just a running light.
if I doesn't I guess maybe if both of the others bulbs wnet bad at the same time, because they are running lights but also blinker / brake lights.
Would be a STRANGE coincidence if the brake/blinker element went bad on BOTH lights at the same time....
