Passing lights quit
Just noticed it yesterday while at the Lone Star Rally. I figured it was just a fuse until I went to change it out. The switch is typically illuminated but it's not now, so I doubt it's the bulbs. I haven't had time yet to put a meter on it, but I will after work. I'm fixing to replace them with reflector LED's anyway
don't bother checking the bulbs- if no light at the switch, then it isn;t getting power.
high beam switch first ( unless modded- in which case check your mod)...
then work backwards
I don;t have a wiring diagram for your year, but the fender tip light may be on the same fused circuit- that wire can rub through on the fender
mike
then work backwards
mike
