Long Ride Shields 60% off code
#91
#92
Got mine quick. Reno, NV to Phoenix, AZ. Mine looks great. I ordered the 16" windshield but it came in closer to 15". Not a big deal, looks great. Make sure you get double sided tape ahead of time for the hardware so you don't have to make a run in the middle of the project like I did. What I like the most is that it doesn't touch my apes like the HD windshield!
#93
GibsonSG05
"I ordered the 16" windshield but it came in closer to 15"
Yeah, mine was the same way. I ordered the 16 as well, and its not 16 inches. Maybe 16 from the headlight to the top of the shield, but not from the bottom of the headlight opening to the top of the shield. Also, did you notice the shield has a very slight milky haze. I suspect that's some sort of coating, but the shield is not crystal, or glass clear like the factory HD shield is. Just wondering, because I LOVE that my eyes don't tear up on cold mornings any more.
#94
GibsonSG05
#95
GibsonSG05
They measure the RK shield from the cutout (headlight) to the top of the shield, so this is why it seems shorter than you thought. I am not sure about your shield, because I do not know what you ordered, but I do know that they found a defect in the light tint material, so if your shield is a light tint, than it could be a defect, you can call lrs and check with them to find out.
#96
#97
#98
Yours looks great. And honesty, I love mine. I just wanted to share what I was talking about. Here's the new Long Ride mounted up, next to the factory part. Is it me, or is there some haze or maybe some sort of anti glare coating? Because it seems to be part of the shield itself.
My MOCO windshield is on the right. The LRS is mounted.
#99
There's double sided tape that secures the hardware to the windshield. You'll have to remove it when you remove the hardware from your original windshield. I'm not sure if it is 100% necessary but I like the idea of not having the metal hardware right up against the poly windshield. The 3M tape I used from Autozone was about 1/16 or 1/8" thick and gives a little bit of padding between the two surfaces.
#100
