Long Ride Shields 60% off code
#72
Only issue I've had and read about with LRS is that there acrylic shields tend to crack around the screw holes. I discovered mine was cracked when I took it off to clean behind the windshield bag. I did a search and found a thread with others having the same issue. LRS says it's probably caused by the mounting screws being over tightened.
The Elite series doesn't seem to have that issue. That's why I ordered the Ultra Elite this time. It's made from polycarbonate and has a glass hard coating to resist scratching.
#73
I ordered mine around 8:00 pm on the 11th. Got a confirmation email within minutes, received an email on the 17th dating it had shipped with the tracking number. When I check the tracking number on the USPS website it shows it will be delivered today.
#74
#77
#78
#79
#80
It's possible they sent the wrong one. Are you sure you ordered the correct one? They are listed as 2014 Ultra or Ultra Elite for the 14 & 15 and just Ultra or Ultra Elite for the 13 and older. Even if you ordered the wrong one, LRS will exchange it for you as long as you haven't removed the protective wrap.
