Fuel octane
Fuel octane
I just returned from a trip with a friend from S. Florida to the Four Corners in N. Mexico of 4800 miles great trip. A couple of question's riding up in Arizona and N. Mexico the fuel octane was 90 - 91 octane. As Harley recommends 93 octane how does that work out all year. I noticed some pinging on the highway at times while accelerating. Additionally, my friend has a 2014 Ultra that got less mpg than my 2013 Ultra. Just curious.
I thought Harley recommended 91 or better for gas. Don't have my manual right in front of me so I can't double check.
I see 90, 90.5 and 91 when we ride the small towns and some stations I have seen are now including one pump that has 93. You can buy some of the octane booster if needed.
I have a PV on mine and a pretty aggressive timing map. When I start to show pings, generally in the rear cylinder first, I will pull over and load a tune that is a little less aggressive on the timing. If I fill up at a station and I know I am using 90 or 91, I will load the tune right then.
How broken in is your buddy's 2014? I have noticed with both bikes that as they got better MPG after they had decent miles on them, by maybe a gallon at the most. Nothing scientific. Also, the HO engine, cam choice and tuning all will effect mileage.
Our fuel around hers is
87 regular
89 mid grade
91 premium
A BP station right up the road from me has 93 octane ethanol free, that's what I put in my bike. Very few stations around here have the 93. I see Quik Trip is now offering ethanol free here too, don't remember the octane though.
87 regular
89 mid grade
91 premium
My manual ( 09) says 91.
( and riders shouldn;t confuse ethanol additives with octane)
on late models the ECM will retard timing if it senses pinging ( or should...or try to).
the result of retarded timing is less power, less fuel economy.
Riding the 4 corners, you are at elevation= less oxygen/ less power
I may mix premium/reg to get closer to a desired octane value.
sometimes a little bottle of boost in the saddlebags
mike
mike
